When routes are deleted if there are no more routes for a particualr prefix then the route node is also deleted. This message is used to display the error if a route node lookup fails. vr is the name of the vr in which this happened and addr/mask is the prefix of the roue node.
Not a real problem so there is nothing to be resolved.
Debug-Data
during Delete of Route Node %addr%/%mask% Lookup failed resetting compression to start from radix root vr=%vr%
| Name | Type |
| vr | String |
| addr | String |
| mask | IPmasklen |
